New to iPhone and looking for tethering options
Jun 13, 2013
Hi there, Old Android user here and i heard good things about the iPhones so i came to the dark side. Anyways i searched for a bit and it looks like if i want to use my PDANET (on Android) i have to jailbreak my phone. I really don't want to do that as i searched that out and some people were having problems with it working right.
Is there any other options for tethering my PC laptop while on vacation?
liberated
Jul 19, 2007
3,238
488
Yes, if you have a family data shared plan, thetering is included at no additional cost with AT&T
k62
Jun 11, 2013
I ve got the unlimited data packages .
But since I have that I can t get tethering or the sync options on my phone ,anyone else know how I can get wifi from my phone
Sent using iCafe app
5,578
If you don't want to give up unlimited data (which isn't truly unlimited), you'd have to jailbreak and use an unofficial tethering app. However, you may not be able to jailbreak - it depends on which firmware version you're running.
15,385
1,089
Also, depending on your usage, it's possible AT&T can detect/guess you are tethering via jailbreak and force you to change plans.
5,578
True. If you are going to use unofficial tethering, you'll need to keep the overall data usage under about 3 GB/month to stay under the radar. Otherwise you run the risk of getting thrown into a capped plan. This could happen if you use less than 3 GB/month, but it's much less likely.
Jun 13, 2013
I have Verizon, thanks for the help.
15,385
1,089
oh, well in that case, I thought Verizon provided free hotspot.
