Newb Question About 3G
Marino
Jun 7, 2008
24
Macon, GA
Hi, obviously I'm new here, but I just had a question. After 6 months of enjoying an iPod Touch (my first iPod), I want to make the jump to an iPhone. Problem is that where I live isn't in the blue zone of 3G coverage on AT&T's map. So does that mean getting the new iPhone is completely useless? Or would it still work, only not taking advantage of the faster speeds and I could still use it while waiting for ATT to expand their coverage?
Thanks.
tuckerbball
Jun 3, 2007
45
Thanks.
I am not sure but i think they have been extending there coverage this past yr.
psylichon
Oct 31, 2007
16,591
751
41
Philly
I'm guessing there will be little new in regards to features in the new phone other than 3G. However, assuming it doesn't cost a bunch more than the first gen, it makes sense to buy it as an investment in the future, because 3G coverage will improve and in the meantime you'll get Edge support.
However, until we know the full feature set of the new phone, it's impossible to gauge whether it has more value to you compared to the original phone.
stevenshizzle
Jul 9, 2007
34
I'm not quite sure that I use 3G often enough for it to warrant me getting the iPhone 2. I'll have to wait and see what additional features are offered that won't be possible on the current iPhone. Two more days and we'll see!
Marino
Jun 7, 2008
24
Macon, GA
That was my main concern. Obviously we don't know anything 100%, but what you're saying is that it doesn't ONLY have 3G, edge is still built in?
Saverino
Jun 1, 2008
4,480
92
Burbank
Yes, edge is still in there.
Quake97
Jul 10, 2007
522
Philly Burbs
Yeah, 3G is backward compatible with EDGE. You'll always be able to fall back when 3G isn't available. 3G is pretty important as far as speed and the ability to surf and talk at the same time. If you've ever used an iPhone on EDGE, it's pretty rough especially when pulling up actual websites. The iPhone optimized websites are fine, but they aren't the point of the iPhone.
Joe
Marino
Jun 7, 2008
24
Macon, GA
Ok, that's cool.
Now this may be another dumb question, and I'm sure I could go look it up, which I'll try anyway, but does the iPhone have the ability to just use WiFi if it's available like I would with my Touch?
Mar 30, 2008
5,126
Elizabethtown, Kentucky
I think you should still go with the 3G version to stay updated with the newest technology and iPhone features :) As long as the 3G service isn't forced on you to pay an extra fee for usage, I'd go for it. Even if you don't have 3G in your area theirs probably 3G coverage around your job area, or maybe if you happen to go out of town or something.
Where's the closest 3G service near your area?
Saverino
Jun 1, 2008
4,480
92
Burbank
Ok, that's cool.
Yes you can use Wi-Fi with the iPhone.
Saverino
Jun 1, 2008
4,480
92
Burbank
+1
New technology > Older tech.
Marino
Jun 7, 2008
24
Macon, GA
Closest 3G area is Atlanta, which I'm south of. Any time I go out of town though, it's usually to Atlanta.
