Newbie, needs help on ringtone and text sounds
Sash
Jun 26, 2009
19
okay when i get a text it wont make a sound and i have the volume up. and can you set a ringtone as a sms ?
jdinner
Dec 14, 2008
47
Settings > Sounds > New Text Message - choose a tone.
BrownGem
Feb 27, 2009
1,623
22
Texas
You can only choose from the text alerts provided by Apple for SMS or email alerts. If you searth the forum for changing SMS alerts there are ways to add your own but it isn't a really simple process. You can't just set a ringtone as an alert. If you have alerts set and they aren't working try a reboot. Small glitches happen occasionally.
Adman21
Jul 29, 2009
I am having this problem as well. My phone rings just fine but wont make a text preview sound, wont make the lock sound and only alerts me via vib when I get a text. What to do?
KabaModern
Mar 31, 2008
4,549
32
Philadelphia, Pennsylvania
It may sound stupid, but do you have the ringer switch off? Check your settings under Sounds and make sure you have an audible (to you) sound selected and ensure the volume on your phone is up. Try rebooting the iPhone also.
Let us know.
iNinja
Aug 8, 2008
3,984
20
UK
Ive experienced this once before, I think it may be a little bug in 3.0. Just reboot and you should be fine.
That is of course, you have all relevant volumes and sounds on! ;)
