Newest songs no longer at the top?
nlaplaca
Nov 26, 2008
47
I finally updated to ios 5.0.1. and I noticed that my most recently added songs are no longer at the top. They are now at the bottom. No matter what I do with the "Date Added" sort tab. This is not making me too happy. Anyone else find this troubling? Or better yet anyone know a way around this?
For quite some time I have had my most recently added songs to a given playlist at the top. Now I have to scroll all the way to the bottom to get to them. Nick does not like this.
nlaplaca
Nov 26, 2008
47
Found a workaround in another forum. If you are having a problem with IOS5 and iTunes 10.5.1 not honoring sort tabs on the iPhone after syncing then you can set your playlist the way you want it sorted, then duplicate that playlist. Don't touch anything in that list. Sync and the new playlist will be just as it is in iTunes. Then simply delete the other playlist and rename the newer one.
