News Application?
jerrettpaul
110
Denton, TX
does anyone know of a good news application? if so let me know, and if someone cares to develope a good one (if it doesn't exist already) more power to you, id use it an appreciate it fo sho!:laugh2:
jerrettpaul
110
Denton, TX
last question, i have it on there, so now how to i add feeds? thanks for the help!
jerrettpaul
110
Denton, TX
I seem to be having toruble adding feeds...can you tell me what I would need to do?
Thanks..
Marc
yeah i was having the same problem but i figured out you have to put the WHOLE URL. so for example for CNN world news the feed address is
http://rss.cnn.com/rss/cnn_world.rss
you have to type all of that including the HTTP://
kind of tricky, but easy once you figure it out!
hope that helps!
marcf
Jul 10, 2007
37
wisegrape
Sep 23, 2007
Settings saved after restore?
I installed MobileRSS and it started up Digg's feed automatically. OK looks cool. I then wanted to setup a Digg/Apple feed and removed the digg main feed when going through the settings. I went out using the home button and then back in to MobileRSS and it was blank. This was expected as I had removed all feeds. I went and added the digg Apple rss feed using the entire link "http://digg.com/rss/indexApple.com". It was blank. I couldn't get it to work and didn't mess with it much more. I got tired of messing with it and decided to restore my phone as i was a little paranoid about all of the mods. Well after restoring the phone I decided to mod again as I was bored with the default phone. One thing I noticed when I re-installed MobileRSS is that my old settings were still there. I thought that the restore would set it back to original but I guess after the restore and reloading with my last sync it copied all of my settings back over. I have since realized the rss feed I was trying before was incorrect and should have been "http://digg.com/rss/indexApple.xml" so MobileRSS is now working. I just need to try to understand how to get my phone back to factory and "activate" with my current number. I'm sure I'll need this information in the future as I'm sure Apple is working hard to completely lock out mods. Also couldn't AT&T tell when people are installing mods using the installer app when connected to EDGE? Time to search... Any help would be greatly appreciated.
