Newsstand
Mace0283
Jan 1, 2012
22
Has anyone been having trouble with opening the newsstand? I downloaded a new magazine and when I tap the newsstand to read it, it just switches to my lock screen.... Very irritating!
Sent using iCafe app
It's crashing and causing a respring. It will do this if you have Newsstand in a folder. Remove it from the folder if you do. If you don't have it in a folder, try rebooting the iPad and see if that fixes it.
Mace0283
Jan 1, 2012
22
Awesome! Thanks for the tip! It worked! I hate that you can't have it in a folder.... Oh well.. As long as it works.. Thanks again
Glad that fixed it for you. Yeah, unfortunately, only people who don't use it at all can put it in a folder.
