Next SIM/turbo SIM - not working?
tok
Jan 20, 2008
Hi
Have downgraded a 1.1.2 ootb to 1.1.1. Is now using a next sim together with my normal sim card (TDC-Denmark).
When I turn on the phone it asks to unlock sim, and when I enter my code it unlocks perfectly. However I will never connect to the network - I can not call/receive calls.
Does anyone know what to do here?
Thanks a lot in advance.
KNK
Jul 22, 2007
2,391
Stevenson Ranch
Hi
Did you do all of the process yourself or did you buy it already done?
tok
Jan 20, 2008
Turbosim
Maybe someone could tell me what to look for in the settings to be sure it is done the right way - maybe it is the turbo/next sim that does not work correctly.
gombe
Feb 1, 2008
Did you figure this out? I am having the exact same problem!
tok
Jan 20, 2008
Yes I have solved this now.
You simply have to upgrade to 1.1.2. again
