Next steps after downloading IPSW to desktop?
ZJH90
Jul 26, 2007
105
San Francisco!!!!
Every time download the ispw, it turns into a folder in my desktop called "iPhone1,2_2". What do I do from this point?
enigmanic
Jun 27, 2007
513
Are you using a Mac? If so, Safari automatically unzips the ipsw file, which you do NOT want. Instead, right click over the link and choose "Download Linked File As". This will ensure that the .ipsw file remains intact. Alternatively, you can use Firefox, which doesn't automatically unzip files.
paa79594
Jul 23, 2007
547
Los Angeles
www.theplasticguys.com
Yeah, or just download it, and remove the ".zip" from the file extension, and it'll leave the ".ipsw" intact. Then, you can use iTunes to update your software. Do a backup first though.
ColsTiger
Mar 8, 2007
5,856
Columbus, GA
Be sure to fully sync prior to proceeding. In order to install this firmware, you will have to do it manually by pressing the Option key (Shift under Windows) when pressing the "Check for Update" button in iTunes version 7.7. Then select the .ipsw file manually. If for some reason your download is a ".zip" file, rename it to ".ipsw" before proceeding.
