NFL Carrier Logos
420greg
Jun 26, 2007
845
Orlando, Florida
****UPDATE*****
This set is now available via the installer app.
There are in the main installer menu under images. They are part of the customize designer image set released on 9/28/2007.
The linked zip files contains NFL carrier logos (Default and FSO) for all 32 teams.
If you are using customize (formally docswap) on your iPhone then follow these steps:
After you unzip the file you will have a folder called 'nfl' this entire folder needs to got to /private/var/root/Library/Customize/CarrierImages/ on your iPhone.
Depending on the program you use to browse your iPhone you may need to crate the NFL folder manual then move the contents of the nfl folder from the zip file to the newly created folder.
When you are done restart your phone and go to customize | carrier images. There should be a whole new section called 'NFL' below 'Designer'.
You don't have to install them all. You can make the NFL directory on your iPhone and just drag over the team(s) you want.
Right click choose save file as http://unevenpavement.com/nfl.zip
Enjoy!
/NCAA Logos coming soon.
domi
Aug 13, 2007
84
Texas
Enjoy!
Good job! these are pretty awesome. Can you repost the file because it didn't work when i tried to download the .zip file. thanks a lot!
unknownentry
Jul 19, 2007
204
Knoxville, TN
www.iphonesurge.com
Enjoy!
That's awesome! I have actually been working on the same idea! We need to talk. I sent you a PM! :cool:
420greg
Jun 26, 2007
845
Orlando, Florida
I reposted it to my webserver. If you are still having problems let me know and I will email it to you.
lucky8926
Jun 16, 2007
217
Central IL
This is the step i'm having problems with.... How do I get the folder to "/private/var/root/Library/Customize/CarrierImages/" on my phone? I have apptapp, customize, breezy all installed....
Popdevil
Jul 2, 2007
254
It would be great if you had this as a install from the installer.app or on ishare.
420greg
Jun 26, 2007
845
Orlando, Florida
You need to ssh in to your phone.
On your iPhone via installer install the bsd subsystem and open ssh.
On your computer install winSCP (windows) or Fugu (mac) and connect to your phone and navigate to /private/var/root/Library/Customize/CarrierImages/
Place the NFL folder there.
I am going to PM x999x about how to make these available via ishare for those that do not want to ssh in to their iPhone.
hoits2000
Mar 15, 2007
360
What the crap is breezy? is it on the phone or the computer?
420greg
Jun 26, 2007
845
Orlando, Florida
I couldn't agree more! ;)
I am working on it. I sent the files to spicychicken to see if they can add them to customize, and I also PM'ed x999x to see about using iShare to distribute the files.
I will post here when I have a solution.
Popdevil
Jul 2, 2007
254
I have installed the BSD and SSH on the iPhone and installed WinSCP on my computer. What settings are needed for the WinSCP to connect to the iPhone?
Can you provide a screen shot?
420greg
Jun 26, 2007
845
Orlando, Florida
I have a mac so no screen shot of winSCP but here are the settings;
connect to: ip of you phone, go to wifi and click the blue arrow to get the ip.
port: 22
user: root
pass: dottie
