No 3G on "3 Network" on iOS6.
InertProtocol
Sep 26, 2012
Hi,
I am on the "Three" Network, and since updating to IOS6 i no longer am able to connect to 3G/Mobile Data. This worked fine before and WiFi works fine.
If it makes any difference i'm using an iPhone 4.
does anyone ahve any idea what could possibly be wrong?.
IllusionEntity
Jun 3, 2010
1,990
163
Borough Green, Kent, UK
Hi,
Depends how long you haven't had 3G for. Check your settings first. I sometimes don't have 3G on 3 for a couple of days due to a problem on their part.
InertProtocol
Sep 26, 2012
Thanks for that.
It's been about 24 hours now. When you say settings, Mobile Data is ON which is all i had to do before.
A known issues then is it?.
