No more car phone with 1.1.1?
arothman
Jul 28, 2007
74
Prior to 1.1.1, if I had the iPhone playing through my car stereo, I could make a call on 'speaker' and it would play through the car speakers. Now it only goes through the phone speaker, which I can't hear while driving. Anyone else?
bigmac
Jul 13, 2007
110
Los Angeles
what are you using to play through car speakers?
6,682
49
Generally, if you are connected through the headphone jack, if you are using a regular 3 band headphone jack, the phone ignores it as a source to play a call's audio through.
With a 4 band adapter, like the Seidio one I have with the inline mic, that works fine.
arothman
Jul 28, 2007
74
I'm using a 6" gray cable from Radio Shack which I stripped the plastic from at the end to get it to fit. Before the update I could hear through the car speakers when I hit 'speaker', but now I can't. Maybe I just need to play with it a little more. Either way, I have a bluetooth headset which I prefer for car calls anyway. :cool:
Tinman
4,334
183
Aridzona
That's not true. Before the update I used 3-conductor to line-in just fine to receive calls. The only thing I had to do was use the phone's mic to speak (obviously).
After the update it works exactly the same, in the test I just tried (this time with standard headphones, whittled down to fit the iPhone).
Mike
arothman
Jul 28, 2007
74
Good to know... maybe I didn't have it plugged in right... :)
Tinman
4,334
183
Aridzona
yes if you are also using "whittled down" connectors that could be the case. When I first tried it (just a little while ago) I didn't have the plug in all of the way and the mic didn't work on the phone (but I still got stereo sound).
Mike
DocHolliday
Sep 28, 2007
53
Can you post a link to which adapter with inline mic you're using? Thanks.
6,682
49
there used to be a listing for the adapter in the store here, but I was unable to locate it. Go to www.seidio.com, and then go to the store, choose iPhone accessories, and then audio adapters.
I use mine all the time and the only complaint I ever received was that I sounded like I was on speakerphone.
great little device for 15 bucks.
arothman
Jul 28, 2007
74
I tried this again and it's definitely not working. Before when the phone rang, I could just hit 'speaker' and it'd go into the car's stereo. Now it doesn't. You guys say it's working for you still?
Tinman
4,334
183
Aridzona
Definitely worked for me on 1.1.1 and on 1.0.2.
To be clear I first had to tap Answer to take the call; tapping Speaker turned on the (iPhone's) mic, which was muted till doing so.
That said I can't test 1.1.1 anymore as I have now rolled back to 1.0.2. Still works the same though.
Mike
arothman
Jul 28, 2007
74
See, in my case, I'm listening to the iPod, and then it fades out and I hear the ringing, so I hit 'Answer' and it picks up the call, but I can't hear anything. If I hit 'Speaker', it simply goes to the iPhone's own speakers instead of through the headphone jack to the car's speakers.
saaber
Jul 23, 2007
78
Be warned that I bought this seidio adapter and it reduces the volume coming from the phone by about 80%. I get full volume when connected directly to the iPhone but when it goes through the seidio adapter it is barely audible.
6,682
49
Again, that's YOUR experience, and not the norm.
