No NES ROM's were Found. can some one help me?
ja_vo
Jun 17, 2007
236
Atlanta, GA
Please upload ROM's to
/var/root/Media/ROMs/NES
hey guys that is the message i get when i click on the NES app. i use AppTap to download it but i need to get the ROM's and i need to know how to install them can some one please help me do it please. im sorry i have no idea and its my first mod.
thank you so much guy/girls!
Javo
sp33d
Aug 28, 2007
Javo
Save yourself the time, chances are you won't even play it because it's so difficult to. But to answer your question, use iBrickr to install the Roms.
Pharaoh
Sep 7, 2007
91
install ibrickr, connect iPhone to dock.
you can navigate the folders in the iPhone using ibrickr, and create new folders such as for ROMs/NES/ in the media section. then just upload the rom file in the NES folder and its done. I just finished it, got about 20 roms on it
xcell
Sep 21, 2007
What would be a Mac compatible software like "ibrickr"?
thesheikh
Sep 16, 2007
whewre do you get the nes roms...can u give me a link or something
akophone
Aug 1, 2007
300
App called breezy would be the "ibrickr" for the mac. But if you want to install roms, I would suggest you perform SSH for easy drag and drop. If you have Installer on your phone, install BSD Subsystem and then the oPenSSH. Download Cyberduck or Fugu and connect to your phone using sftp. Then create the appropriate folders where the roms will be residing.
Pharaoh
Sep 7, 2007
91
since roms are illegal, i cant give you a direct link to a site with downloadable roms. You can do a simple Google search for 'NES Roms'. Any rom you download will be compatible with the NES emulator on your phone. Shareware like limewire or torrents will have packages of them together, a lot of times like a thousand NES games in one download. You then understand how to get these roms on your phone from my explanation right?
thesheikh
Sep 16, 2007
yes i know how to do that but how do i know im downloading the right rom
sp33d
Aug 28, 2007
use a NES emulator and play the game on your pc to see if it works.
Pharaoh
Sep 7, 2007
91
any NES rom you download will be compatible with this Emulator
DeeRector2
Aug 30, 2007
54
Ok, I installed FUGU. How do I get into my phone with Fugu? This is where im lost...
DeeRector2
Aug 30, 2007
54
Awesome thanks for that link. That helped me out bigtime. But now check this out.... When I drag a theme into my theme folder, the file drags over with all contents in it....But now when I select that theme on my phone, it just goes to a black springboard and regular icons.. very similar to the stock springboard. Any idea whats happening?
Try this guide.
If that doesn't work, try Cyberduck. Same idea. Good luck!
akophone
Aug 1, 2007
300
Okay, do this:
Make sure you put all the icons in a folder labeled Icons and leave Thumbs.db and Wallpaper.png out.
Then put all of these inside a folder with whatever name you want (Halo 3 Theme, etc.).
SSH and put this inside Summerboard/Themes. Good luck!
DeeRector2
Aug 30, 2007
54
The SSH part confuses me. What to you mean by that?
Okay, do this:
DeeRector2
Aug 30, 2007
54
Yeah I know about that link. You sent that one to me and it was very helpful.........once I drag the theme folders with the icons (separate folder) into the correct folder, the folder does appear in my phone, but my phone just loads a stock springboard. I tried doing this with a few different themes and it happens with all of them. Im def. missing something. Does anyone know?
Use Fugu or Cyberduck from this guide.
This allows you to drag and drop the themes in the Summerboard theme folder.(var/root/Library/Summerboard/Themes).
