No Network signal
denzzz28
Nov 30, 2011
I manage to cut the power and volume ribbon cable and I also cut the wifi antenna whilst trying to dismantle the screen. so I bought new parts and replace the ones that i damaged. put everything back so the power and volume buttons are now working and the Wifi signal is back but when it put the sim card back I could not get a network signal? I re opened to check if i missed any cables but everything was back.
don't know what to check anymore... need help please...
AZIANAPPLE
Jun 6, 2012
181
9
The best thing to do if you get steered away from your concentration is to use a reference diagram of what you are doing. Check ifixit.com. That helped me when I dismantled my 3G to refurbish my device.
N
Normany Clark
Guest
I agree with you. ifixit.com is really working for mine also.
