No option to cut calls when busy
rugved1118
Sep 27, 2013
642
Hello,
Actually i have this problem eversince ios 7 is installed. When i am busy and do not want to attend incoming calls, i only see two options :
1. Green button
2. Remind me in 1 hour OR when i leave.
I have to select "remind me in 1 hour" and then have to delete manually from reminders which is big pain for me.
May i know where has the RED button gone missing ?
Sent from my iPhone 5S
Nrevezzo
Apr 15, 2009
104
23
Canton, Mi
I noticed this also. If your phone is locked then the red decline button is not presented but if you're using an app or the phone is unlocked then it is presented as an option. Of course I only just noticed this because of all the political calls I've been getting the last few days. Thankfully it'll be over tomorrrow; at least for a little while.
Lon
Jun 5, 2010
2,946
132
Alaska
AMEN!!
Kadelic
Jan 4, 2010
4,938
1,645
Dallas, TX
Just press the volume button to silence the ringing and ignore it.
Doesn't pressing the lock button do something to an incoming call as well? Or was that an older iOS version? The volume button silences and ignores the call, but still lets it go through to voicemail. IIRC the lock button would not just ignore the call, but essentially hang up on the caller. It's been awhile since I've had to use those options.
28,365
5,506
Pressing the lock button while on the lock screen used to decline the call and send it straight to voicemail while pressing a volume button would silence it. Pressing any of the buttons just silences it now. The only way to decline a call and send it straight to voicemail now (from the lockscreen) is to select Remind Me.
