No options to turn off push notifications?
reginaalear
Jun 21, 2010
480
24
Western Kentucky
For some reason I have no options to turn my push notifications on or off. When I click on notifications all it has is manual or by time. Is there a way to get the on/off option back on it? I'm not sure why it's gone. Thanks.
iNurse
Nov 11, 2011
559
The Volunteer State of Tennessee
Think that is just for the notifications center that you can view by swiping down... or what pops up on your screen and how..
Under your mail settings is where you can set your push....and how frequently, fetch...etc
This is what it looks like:
My husbands is the same way. They used to say push on/off but not anymore.
It was changed a little in 5.0. Now you need to scroll down to the specific app and customize the notifications. They are listed under 'In Notification Center' and 'Not in Notification Center'.
Here is an example of an app with push notifications off:
Yes, that looks right.
Here is clarification in case anyone else is wondering:
Push Email:
Settings > Mail, Contacts, Calandars > Fetch New Data > Push > On
Push notifications for all other apps:
Settings > Notifications > In Notification Center/Not in Notification Center > Select the app you want to configure > Notification Centet > On > Select alert style (banners or alerts)
  • Like
Reactions: iNurse
