No ring on calls, just voicemail
Sep 2, 2011
Hi group,
I have a new Samsung Fascinate. Sometimes, phone calls to my phone do not ring but go straight to voicemail. There is no record of the call in the call log, only the voicemail, and the phone is not turned off. Anybody else experiencing this?
Bennyboy
Jul 21, 2010
14,017
1,756
PA
Huh? you know that's an Android right?
Bennyboy
Jul 21, 2010
14,017
1,756
PA
When that happens to my iPhone it's usually because I have no signal.
can you reset your network settings and see if that fixes it?
BBGT2
Sep 28, 2007
172
Are you rooted? If so what ROM are you using?
If yes to any above, how is your signal strength? Try flashing a different modem.
Sent from my iPad using Tapatalk
5,580
Thread moved to Off Topic.
