no service signal
abediman
Dec 23, 2008
i upgrade my iPhone 3g to 2.2 and jailbreak it with QuickPwn22
but the problem when i turn on my phone i get provider signal then where the signal bar i got no service
please can i get help with issue
thanks in advance for all
BigCiX
Jul 11, 2008
1,445
Bakersfield, CA
Try restoring your phone and in again. See if that'll work. But before
U do that do a quick reset (hold home and power button until the Apple sign shows up again)
abediman
Dec 23, 2008
I tried more than 3 times and it didn't work
tiguy99
Nov 28, 2007
154
Chicago
Reset network settings then properly setup your APN etc depending to your provider
yanki
Nov 23, 2008
41
Puerto Rico
if your phone is using a proxy sim... your proxy sim is probabbly for 2.1, not 2.2... leaving you in the same boat with others that didn't read before upgrading... including me... i had to buy a new proxy sim
PepeRB29
Mar 21, 2008
1,500
8 mile
^gotta love when people don't research before doing something important.
to the OP, if you aren't using a proxy sim, i would recommend restoring and doing what the others said, but i would be willing to bet you are in the proxy sim boat.
abediman
Dec 23, 2008
Thanks for your information
if we bought a new turbo sim for 2.2 it will normally?
and from where i can get it?
thanks in advance
