No SIM card/ invalid SIM card
Johnlennon78
Dec 25, 2011
43
Hello guys,
I have been experimenting some weird stuff on my iPhone 4s since yesterday. I will get the message invalid sim card on my iPhone. I turned it off, started it again and it was fine. I could get and make phone calls , send and receive SMS. After ten min or so new message appeared which says no sim card. Tried to reboot 3x, with no result. Left iPhone off for about 15 min and turned it on, now it works. Left it on for the whole day no prob. This scares me as I have never dropped the phone. I have ios 5.1.1 which was the latest as of yesterday. Has anyone of you experienced the same thing? Should I go back to the store and returned it since I still have a warranty on it until novmeber? Thank you for your suggestions!
Yes, I experienced this a few times on my iPhone 4. Removing the SIM and putting it back in should fix the problem.
Johnlennon78
Dec 25, 2011
43
yes! I forgot to mention I did remove the sim card a few times the second time it happened to me.
You still have a couple months of warranty if you want to see if it keeps doing it. I never replaced mine because reseating the SIM always worked. But if it does continue to do this, I recommend getting a replacement SIM card at AT&T and restoring to factory settings before replacing the phone.
