No sound for incoming SMS
magnum man
Jun 10, 2007
100
Anyone else having this problem? It works fine when I get a call, but it makes no sound for a text message. And yes I have SMS notification turned on
lady_bugz22
Jun 13, 2008
484
DFW, TX
I think its part of the glitch in 2.0 It happened to me yesterday so I turned my phone off & turned it back on after a couple of seconds. It hasn't happened anymore.
jbarrack
Jul 2, 2007
453
New York
www.facebook.com
Yeah this happened to my uncle the other day. He just shut it off and turned it back on like lady_bugz22 did and he had no problems after that ... Im sure an update will be in the works fixing this.
TAEWING59
Jul 12, 2008
344
Id update to the new build 5A347 is suppost to be so much better, and fixes a lot of issues, haven't got my phone, but if somethings not working right, ill update
TAEWING59
Jul 12, 2008
344
idk then, maybe the ringtone you have set us messed up
iFerg
Jul 17, 2008
yes same thing keeps happening to me. im tired of rebooting my phone so im restoring my iPhone to the 5A347 build right now. hopefully it fixes the bug. its rather annoying.
magnum man
Jun 10, 2007
100
Did it fix the bug for you iFerg? Because I still have to constantly turn my off and back on because the sound keeps going out on it.
Usually sound issues like these can be fixed with a rather simple method. Go to Settings > General > Reset > Reset All Settings.
iFerg
Jul 17, 2008
magnum man: nope didn't fix the prob for me still does it.. but it happns less now tho.. im gonna try to setting reset when it happns again to see what happns...
just found out rather than always resetting the settings its easier to just change the text sound to another one then that fixes the problem also.
