No sound making/receiving calls + not ringing
blankman
Jun 26, 2009
Hi. I am having a problem with receiving calls on my i phone 3G.
Firstly it does not ring and then if I do realize I'm receiving a call and answer it, there is no sound at the other end and they cannot hear me.
To get over this I have to turn to the phone off and on again then it works as normal. This has happened a few times since the 3.0 update
My phone is jail broken using redsn0w and ultrasn0w, and have also installed many further apps from cydia.
Has anyone else had a similar problem. does anyone know of any 3rd party app that could be causing this.
Thanks for you help.
maastab8
Dec 4, 2009
I'm having the exact same problem on 3gs running 3.1.2. Jailbroken, too. So, have you figured out what could cause this? I'm getting sick of constant respringing.
