No Sound!
I have restarted it, checked all my sound settings, obviously checked the volume. and nothing. When I go to settings to change ringtones, I can hear them. But nothing else. No clicks when I dial numbers, I have vibrate off and Silent Off.
jptolife
Jul 15, 2007
645
New York City
That's what happened to me too, but a reset worked for me. Try resetting again I guess, don't know what else to tell you. The speaker works, as you know since you can hear the ringtones, so I don't know. Keep resetting. It never happened to me again.
jeffp
Jul 9, 2007
23
If you have used the earphones or anything else in the earphone jack there is a chance that the switch that turns off the phone sound is stuck. Plug the earphones in and out of the jack and see if you can free up the switch.
mjeagent
Jun 28, 2007
418
Northern Virginia
Andy - this same thing happened to me after I used my Belkin adapter for my auxillary plug in the car. I had to put my earbud plug in, push down and jiggle the plug aggressively to force the circuit to close -- then pull the plug out and see what happens.
This solved my issue - - hopefully it solves yours.
Thanks, but another question is could it have something to do with me hooking it up to my headunit? It runs an iPod chord straight from the headunit. It's made for iPod. Didn't know if it could have switched something either.
Heckler
19
Happened to me...had to reinsert the headphones, listened to music for a second and then unplugged. Sound was working fine after that. So far it has been just a one time occurrence.
JASmine
Jun 22, 2007
Any chance that the 'mute' switch on the side of the phone is on?
I've tried the headphone thing, pushed it in there, listened on headphones. That works. Unplugged and replugged, rebooted, checked all sound settings. Nothing :( Fearing that I might have to dare I say...... take it back. :(. For a new one of course!
mjeagent
Jun 28, 2007
418
Northern Virginia
I remember that I also did a full restore when my sound went. You might want to consider this as your last resort. I did a full restore, then put the earbud plug in - pushed down with some good pressure while twisting it around. I did this for about 3-5 seconds and all the sudden heard a 1-2 second noise come from the speaker. Unplugged the earbuds and all was fine.
mjeagent
Jun 28, 2007
418
Northern Virginia
Andy - also, keep in mind that if a restore and jiggling the earbud plug does not work you will most likely be exchanging the phone. So, make sure you really give that plug a good bit or pressure and wiggle it aggressively back and forth when it is in.
I am almost positive that you have a stuck sensor within the jack. When your earbuds are unplugged the sensor is staying open, thus, telling the iPhone to put all sound through the headphone jack.
This happen to me once and I scrambled the various forums to try and get help. Finally, someone told me to do this and it worked. I have yet to have the problem again, but I have also not plugged it into my car again via the Belkin adapter.
uPhone559
Jul 18, 2007
389
haha, i couldn't hear any clicks on the phone than i read this thread
glad you posted such a sarcastic reply or i'd be on Apple support right now! thanks
shawndre
Sep 16, 2007
my phone wont play any sounds such as ringing, and the keys clicking. music still plays. i did a restore and it still didn't work. anyone know how to fix this? thank you
chcorey52
Dec 25, 2007
556
Did you set up as new or restore from backup?
termleech
Sep 7, 2007
1,154
McPherson, KS
Did you try the old plug and unplug the headphones a couple times?
