No vibration for phone calls
radtechy
Jul 20, 2011
505
41
I won't get vibration for my calls while on silent all of a sudden.
The vibe does work when I toggle between vibe/ring
Sent from my iPhone 5 using iCafe
radtechy
Jul 20, 2011
505
41
Yes. Everything is set the way it should be
Sent from my iPhone 5 using Tapatalk
VOLS34
Jun 25, 2010
1,119
79
If its a contact check in contacts to see what their's is set on.
radtechy
Jul 20, 2011
505
41
It's anyone. Even numbers not in my phonebpok
VOLS34
Jun 25, 2010
1,119
79
Go to sounds in your settings. Click on whatever your default ringtone is. At the top it should say what your default vibration pattern is or none if you don't have one set. If that's not it I don't know what else it could be. If it vibrates when you toggle from silent to ring it's not a hardware issue.
radtechy
Jul 20, 2011
505
41
Good idea but no good.
I think it's time to the flash iOS and restore
VOLS34
Jun 25, 2010
1,119
79
Do you have do not disturb on? I would try a hard reset before a restore.
radtechy
Jul 20, 2011
505
41
Is that power and home until the Apple logo shows?
DND is never used by me
radtechy
Jul 20, 2011
505
41
That still didn't work. I'm gonna reload iOS and backup and restore
VOLS34
Jun 25, 2010
1,119
79
Sounds like a bit much when it's probably something simple. I would reset all settings & go from there.
radtechy
Jul 20, 2011
505
41
I got it working. Very weird. I tried the adding vibe to the ring for calls even though it was never on.
Now I reloaded the software and it still didn't work now I tried adding the vibe again and it worked.
This is just puzzling in the first place.
Thanks for helping me out. That idea did solve the problem
