no YouTube
May 12, 2009
14
For some reason I can't see any YouTube videos when I open the YouTube icon it says cannot connect to YouTube any idea how to fix this
Youngbinks
Jun 4, 2007
7,617
31
Atlanta, Georgia
Are you running the Beta 3.0? There were YouTube issues on a few of the builds.
If not have you tried a soft reset by holding the home and power buttons? I would suggest that and then if it doesn't work I would say try a restore.
May 12, 2009
14
no not running the beta 3.0... I will try the reset but if it doesn't work and i do a restore will I lose everything? can I get it back to were it is by what is synced in iTunes?
