Noob needs help with WinSCP
Aug 31, 2009
Hi i have heard nothing but good things about this site i just jail broke my iPhone and i want to install apps via Winscp on my 3g 3.0 iPhone but i just cant figure it out i have googled it youtube it and cant find anything that works can anyone help me out thanks.
28,365
5,507
Have you considered just using iPhoneBrowser? It's free and gives you root access to your phone. It's just not wireless, you have to connect the phone to the computer with the USB cable.
Aug 31, 2009
I found a lot of cool app on a web site and i want to put on my iPhone.
RossMc
Jun 28, 2009
1,124
Newcastle, UK
Open Cydia and in the search type in SSH and download Automatic SSH and also Toggle SSH
Once thats done download WinSCP from Here
Once you have downloaded and installed it open the Program
Go onto your iPhone find the open the Toggle SSH Program and click Enable
Then on your iPhone go to Settings > Wi-Fi then click on your network and note down the IP Address.
Once you have got this open WinSCP and in the host name box type your IP address
In the username box type root and in the password box type alpine
Then press save then login and then it will come up with a warning about a key file just press yes
Then it will ask for a password just type in alpine then thats it your done.
Aug 31, 2009
RossMc and everyone else thanks for the reply's.RossMc I already got the iPhone to connect to winscp what i can't figure out is how to install app with winscp i found the folder where all the other app are and i put a new app in there it go's in fine and i reboot the phone and when it restart the app shows up and then when i start the app it just open's and then close's any ideas and thanks again for the reply
Aug 31, 2009
Games and utility app from sites like pdroms
