Notes question..
Jul 3, 2007
Am I just imagining things or is the, 'notes' feature organized just by date. Why not by topics?! exmp. a notes folder called utilities 4 all information regarding this topic. It just seems logical. It's basically the only thing holding me back from buying an iPhone. Any thoughts? Thanks
S
Starry
Guest
I make my first line the "Topic" and then put my info in there... it works just fine :) Come on go buy an iPhone... you won't use ANY other phone! Its awesome!
IphoneTony
Nov 10, 2007
2,163
New Jersey
I do it the same as starry works fine for me. Its not the best note system but its a yellow note pad. What else
Youngbinks
Jun 4, 2007
7,617
31
Atlanta, Georgia
Yeah I too use the first line to tell the topic of the note and it makes the notes much easier to navigate. Notes is easily one of my favorite native applications.
Spikefood
Oct 3, 2007
368
Notes application is as basic as it could get. Hopefully Apple will make the next notes application a bit better overall. Categories would be a good start.
Jul 3, 2007
Thanks every1. I went strait 2 an AT&T store 2 check this info out & you're right. Now the only thing holding me back is that u can't put these notes/files/folders in alphabetical order. Apple really needs 2 make this happen.
Bone
Feb 11, 2008
1,214
I think there are wep application with the thing your looking for in them I know there are sever to choose from. I used to use one reglary but eventually just went back to plain jain notes. You could try looking at appsafari.com. They will have something there I'm Shur to satisfy your needs.
