Odd Cydia Issue with Evasi0n
flightmedic
Jun 21, 2009
397
23
Wichita Falls, Texas
Been JB since day 1, just saw this error today. Not sure what it means or how to fix it. My package list is gone and settings/packages is empty as well, so I can't delete or modify any packages. Also running Evasi0n on my iPad 3 with no problems. Thanks in advance.
5,580
The easiest fix is to restore and rejailbreak. You can use your iTunes/iCloud backup.
5,580
Did you delete your sources with iCleaner?
Is that really one of the options? Yeesh. That app is dangerous, especially for those who don't really understand the file system, etc.
ZR_Yancy
Jul 11, 2008
3,982
737
Yup, but it's disabled by default and when it's enabled, it provides a pop up warning.
5,580
Yup, but it's disabled by default and the when it's enabled, it provides a pop up warning.
Wow. I didn't know it had a toggle to wipe Cydia. I just don't understand why people use this app in the first place. Is temporarily freeing 500 MB really worth it? A lot of it will go right back on there as soon as you use the phone. For example, it clears your cache and settings, but you'll just build a new one and have to put your settings back in and then the freed up space is gone. Why not just truly free up some space by removing a movie or something?
flightmedic
Jun 21, 2009
397
23
Thanks for the advice Europa. Would not allow me to reinstall Cydia. Got the same error. I'm going to restore and re-JB.
I wish I could figure out what was wrong with it though...
Jun 19, 2007
33,493
4,551
Upper Marlboro, MD
I think I had to restore and rejailbreak once because of a jailbreak glitch, so I feel ya, brother.
flightmedic
Jun 21, 2009
397
23
Well. I restored via iTunes and then tried to restore via PkgBackup. Same error. Going to individually install my packages and see how it goes. I've not installed any new packages in the past 5 days and this started yesterday. Also, I do not have any warez/cracked repos that I use either.
Jim
5,580
So how did it go when you didn't use PkgBackup?
flightmedic
Jun 21, 2009
397
23
It worked OK. I did not install as many packages and been running OK. Going to update to 6.1.2 and then re-JB. Going to try PkgBackup first and see if the error reproduces itself. If so no big loss, I know it's the backup I'm using.
Jim
Jun 19, 2007
33,493
4,551
Upper Marlboro, MD
I know it sounds a bit tedious, but before I restore I like to manually save my app data to my hard drive. Then I restore as new, jailbreak, and copy the app data back over.
