Office 2007 - Outlook Calendar
dsmithers
Aug 12, 2009
My contact info in Office 2007 Outlook Contact is not syncing at all - any suggestions? Thanks -
Tinman
4,334
183
Aridzona
Are you certain it is setup correctly within iTunes?
Mike
dsmithers
Aug 12, 2009
I'm not sure - can you tell me what to look for -
Tinman
4,334
183
Aridzona
You need to have your iPhone plugged in, and then in iTunes go to the Info tab. In that tab you tell iTunes with which to sync for both Contacts and Calendars.
I also turn off "Automatically sync when this iPhone is connected" which is on the summary tab.
Mike
dsmithers
Aug 12, 2009
It was set up that way before I emailed the forum -
Tinman
4,334
183
Aridzona
Then it should just work. Never had a problem with using Outlook with my iPhones (either Outlook 2003 or 2007).
Sometimes shutting down Outlook, or even rebooting, is needed in order for the sync to work.
Mike
Aug 13, 2009
