Official iPhone Bluetooth compatibility list
Bear
Oct 20, 2007
Merc
I wonder if the Merc kit is made by Parrot? When I get mine going (if) I'll post a response. Somehow I can't see Merc and VW using the same supplier!
Cobalt
Oct 22, 2007
iPhone with Mercedes
The MHI Bluetooth adapter is produced by Mercedes part no. B6 787 5877 (European) or B6 787 5878 (US)
Clingpeach
Jul 8, 2007
11
I have a 2007 S550 Mercedes. The bluetooth phone function works well with the iPhone.
My question is how can i get the music function to work with the car or is this not possible?
Cobalt
Oct 22, 2007
Are you using Mercedes HFP Bluetooth Module B6 7875878?
Clingpeach
Jul 8, 2007
11
I have the bluetooth that came with the car. Or rather I purchased the available bluetooth accessory
Cobalt
Oct 22, 2007
Does your Bluetooth module look like below
Or is it small and black and made of plastic?
ldr1111
Nov 18, 2007
2008 range rover compatibility ?/
Im having trouble using the iPhone w/ the BT in my 2008 Range Rover?
DotSlash
Nov 25, 2007
which one for my 2006 CLK
which one do YOU use?
does the small black one not work? hope it works in my 2006 CLK, because it's much cheaper than the one from the picture.
cheers
Jens
- from Germany -
Lithium
Nov 26, 2007
Jabra BT800. Works a treat. I'm very surprised, wasn't expecting this to work. Now I'm very happy.
jtomalley
Jan 2, 2008
Jabra BT250v works, BUT...
...the battery life on the BT250v has suddenly dropped from 8-10 days of standby time to about 8-10 HOURS. It worked great with my old Blackberry phone as late as last week but when I paired it with the iPhone, the battery will no longer hold a charge longer than 12 hours tops. Anybody else having bluetooth battery issues with their iPhone? :(
freshtry
Jul 18, 2007
Motorola 350 not working in S550 2007....
mine is not working.. :( we have the same Motorola H350..... why?
I have had the same problem. Initially I can get the car and phone to "discover" each other, but nothing is retained. I may be able to make one or two calls and then the units lose synchronization. My wife's Motorola Razr V3 works perfectly. I have tried turning off WiFi and all other non needed functions but it never re-syncs without going through the whole "discover" process.
I think it may have something to do with the power saver mode of the iPhone. Is there a way to disable this? My wife turned her iPhone back into Apple and refused to activate it. Surprisingly they gave her a full refund. Any thoughts?
llrickman
Jan 12, 2008
787
26
Albuquerque , NM
h700 problem
I have a question. It may have been covered . I have a Motorola H700 and it works well with my iPhone but sometimes it will unpair itself. If you look in the phone it says its paired but when you open the boom it turns that purplish color like when its not paired. To get it to pair again i have to plug the H700 into the wall charger then unpair it on the phone then repair it.
I went to Santa Ana casino in Albuquerque and it does it everytime i go in there other times it has happened is when i leave my phone laying and walk away from it with my earpiece on the come back to it not always but occasionally
Anyone else had this problem? Anyone know what might be causing it?
Larry
