Official Lexus Bluetooth and iPhone Compatibility Discussion
pemarsh
Jun 5, 2007
93
OK. I got bumped up to level 2 tier support with my bluetooth problem. They are saying that the iPhone just does not work with Lexus---"it was not built that way".
Anyways...the problem that I have is when i make an outgoing call, i never hear the phone ring in the car until someone picks up the line on the other end. But even then after it connects, there is a 3-5 second delay in hearing the other person---by then they usually hang up after saying hello multiple times and not hearing me.
mhill
Jul 5, 2007
lexus/bluetooth
I have my iPhone set up in my 05 ls, and my wife has hers set up in her
07 rx400 and we have had no problems. When i dial out using the keypad in the car i do not hear a ring, but when the party answers i do not get the delay you mentioned. Using the one touch dialing in the car i do hear the ring.The signal strength displays and every thing is working fine. There are
several post on the club lexus forums regarding the iPhone I have not seen any post of problems. Could it be a weak signal problem?
dave10425
Jun 25, 2007
Bluetooth HF850 car kit not working with iPhone
I have a motorola bluetooth car kit model HF850 and it pairs ok but when I make a call I cant hear the person and they cant hear me.
maybe the firmware upgrade will help
David-Dick@David-Dick.com
Kippen
Jul 6, 2007
Possible Solution
I have a 2006 GS-300. I've paired the bluetooth with several phones, they always behave the way you describe when I dial a number from the phone. However, when I use the touch screen display in the car, it works just fine. The only trick is that you have to up load all your phone numbers to the car's bluetooth system. I haven't figured out how to do that with the iPhone (I don't think you can). So I used my old RAZR to do it. Everything works fine now!
You can probably pick up an old razr next to nothing on e-bay. There's a solution! I hope this helps!
D
Simon Templar
Jun 30, 2007
39
Infinite Rider On The Big Dogma
I have a Chrysler 300C with the Chrysler UConnect system. If I am not mistaken, the UConnect system is sourced from Johnson Controls as is the Lex system.
Mine works flawlessly. Indeed, it is more compatible than was the Moto RAZR which I was using pre-iphone. It even transmits battery level and signal strength.
.....sT
hiwind
29
i have an is350, noticed the call quality is a lot better than the razor
used to cut in and out all the time
Kippen
Jul 6, 2007
High Pitched Buzz Before Calls
Has anybody heard a high-pitched buzz right before calls connect when using their bluetooth handsfree system in their car? It doesn't happen every time, but about half the time I get a high pitched buzz for about half a second then the phone starts ringing.
I used a RAZR bluetooth for years with the same system and never experienced that.
Anybody?
toothie37
Jul 14, 2007
I have this problem everytime with my 05 rx330
:(..........its scary! I also have problems with i phone/lexus confusing contacts. I'm going to try to erase lexus phone book and reload
Anybody?
LexRexBlue
Anybody?[
I just returned from the dealer. The received an email regarding the same problem. No fix yet. I had a RAZR prior to the iPhone. Fortunately my phone numbers were already entered in. The iPhone uses those programmed numbers.
Kippen
Jul 6, 2007
Has anybody experienced a short buzz, or feedback, when initiating a handsfree call from your Lexus Navi/bluetooth system? I get about a second of feedback on about half of the calls I make from my hands free bluetooth system in my 2006 GS-300.
Anybody?
leeladisky
Jul 12, 2007
21
Anybody?
I do also... i also notice that the sound quality is very poor, muffled and can be effected by the volume controls on the iPhone itself.
Lee
normr
Jul 24, 2007
Can you transfer contacts
The information Lexus has given me so far is that there is no way to transfer contacts from the the iPhone to the vehicle's phonebook and placing any calls from the phone take so long for the bluetooth to actually start processing the audio that people end up hanging up on you.
leeladisky
Jul 12, 2007
21
The Lexus BT system is too tempermental, and has more limitations than my divorce documentation. :-|
mhill
Jul 5, 2007
loud buzz
I have the same loud buzzing problem with my 05 LS. Whatever is causing this, it has been corrected in the new lexus models. My wife does not have this problem in her 07 RX400. Her car also shows the battery meter on the iPhone, and my 05 does not.
Denise
Aug 8, 2007
14
Lexus/iPhone compatibility issues
Mine works with in my 06 IS350.
I currently use a RAZR to connect via bluetooth with my Lexus 2006 RX400h. It works perfectly, but I "need" to get an iPhone. However, according to: http://lexusbluetooth.letstalk.com/brands/lexus-bt/product/product.htm?prId=33077 you cannot use the handset to place a call through the handsfree system i.e if you dial the numbers on the iPhone it won't switch over to the handsfree system. Have you discovered that this is true? Does anyone know if the fix needs to be made by Apple or Lexus?
Thank You
jviphone
Jul 20, 2007
35
Should have bought a BMW, mine was designed for the iPhone..most expensive accessory I had to buy for it though :laugh2:
normr
Jul 24, 2007
That's always been like that
Even before I had my iPhone I had a Razr and if the call is placed from the handset and not the directory on screen the delay is so long before the audio kicks in that people do end up hanging up, it's very poor on Lexus's part, it's not the phone it's the damn car engineers.
