old iPod to new iPod
SweepeR
Oct 1, 2007
367
I have a very old iPod that has songs on it from a computer I no longer use.
If I do an iTunes sync to my current system would it save all the songs on their or would i lose all my songS?
I ask because I have a new iPod on the way and I don't want to lose these old songs on my old ipod as i am giving it away once my new one comes in.
any help on how to keep or store these songs?
Hayesimus
Apr 12, 2012
261
47
If you authorize your current computer using the same Apple ID then it should transfer purchases from your old iPod to your computer. That means songs purchased through iTunes. Any that came from CDs originally will not transfer. There is a better solution but I am not sure if it free or not. I can't remember but I think there was a small purchase price for this program called TuneAid. It will transfer all music from your old iPod into a folder on your computer which can then be added to your iTunes library. Then when your new iPod comes you can sync it. Lemme know if that helps!
Hayesimus
Apr 12, 2012
261
47
You download it on your computer. I used it before when my old computer was fried and I bought a laptop. It worked great. I'm sure there are other programs or solutions but that one worked for me.
Hayesimus
Apr 12, 2012
261
47
And if for some reason the program doesn't detect your iPod when you connect it to your computer, just restart your computer and your iPod and then it should work.
Hayesimus
Apr 12, 2012
261
47
Glad I could help! If you had photos or things like that I think there is another version of the app called disk aid that can retrieve things like that.
Hayesimus
Apr 12, 2012
261
47
Oh really? Lol when I had used it you had to get TuneAid for songs. Guess they changed it.
