Olloclip lens for iPhone 6 and 6+
Bennyboy
Jul 21, 2010
14,017
1,756
PA
Trying to sale mine that I bought for the 5, never used it but had to have it. Never again.
JWiPhone
Sep 18, 2007
6,358
448
Los Angeles, CA
How come? It never worked out for you or you lost interest? I'm not sure if I will buy this. There will probably be cheaper alternatives.
Bennyboy
Jul 21, 2010
14,017
1,756
PA
Taking the case off, I wasn't impressed with micro, same with the wide lens and the fish eye pictures are just ugly. The only reason I really wanted it was for the wide angle lens, won't explain the 80 dollars investment, with only 30 extra bucks I can can a 50mm nikkor for my Nikon.
Bennyboy
Jul 21, 2010
14,017
1,756
PA
And I lost interest too I guess.
I'd be interested in a cheeper alternative, like 20-30 max for a wide angle, that's about it.
Mrallank59
Jan 8, 2013
252
31
I wish the Olloclip had some sort of adapter that would allow you to use it even when your phone is secured in a case.
Ledsteplin
Oct 29, 2013
4,849
1,002
66
Florence, AL
Yep, my Otterbox Defender is a bit of hassle to remove and put back on.
Sent from my ancient but trustworthy iPhone 5.
5,578
It needs to be positioned directly over the phone's camera lens. Cases would create a gap that would make the photos less clear. Also, there is a wide selection of cases available and it would be difficult to make one that was compatible with all of them.
Bennyboy
Jul 21, 2010
14,017
1,756
PA
Does it attach with a magnet?
No, it slides in on the corner so there can't be a case on. They sell similar lens attached to a case, but I don't know either the quality of the case or lens, nor how much it costs.
