omg i am soooo confused right now...
Aug 28, 2007
348
how the heck do i install docks into dockswap b.c it has none when i open it and how do i change the images for the icons?
There are dock images you can download separately in Installer. As for the icons, I ask this question myself.
Aug 28, 2007
348
how do you put in your own.. i followed a guide that said i have to start iPhoneinterface and a bunch of other stuff, does that mean run--> iPhoneinterface, b.c its telling me theres no such file
blurm
Sep 9, 2007
46
Aug 28, 2007
348
im using past 7.4, can i still jailbreak it?
akophone
Aug 1, 2007
300
Try performing SSH to replace icons. Jailbreaking not required. Just be sure you rename the icon to the same name you're replacing and then just drag and drop once connected to your favorite FTP program (using SFTP). You must install BSD Subsystem and then OpenSSH on your iPhone first.
blurm
Sep 9, 2007
46
Try performing SSH to replace icons. Jailbreaking not required. Just be sure you rename the icon to the same name you're replacing and then just drag and drop once connected to your favorite FTP program (using SFTP). You must install BSD Subsystem and then OpenSSH on your iPhone first.[/quote
yes I was pretty sure there was another way to do it, and I had one question concerning the FTP program. Do all of them use the internet to transfer files bc i don't have an available network. I am using a cantennae and am pulling it out of the air.
Aug 28, 2007
348
i decied to just use some summber board themes, thanks anyway guys
