OMG WIFI still doesn't work
RRGOO7
Jul 14, 2007
Ok guys. I think ive tried everything. For some reason my wifi does not work on the wireless in my house. It work at all my friends house except mine!
I have reset my router and my iPhone and still have had NO luck. I was reading in the other reading about typing in some numbers but i couldnt understand where i needed to go on the phone.
My router is Linksys WRT54G and my network has no password.
PLEASE HELP
cdodkin
Jul 2, 2007
305
SoCal
www.d30-images.com
You may need to manually add your DNS server addresses into your iPhone Wi-Fi set-up.
You can check your DNS setting by looking at your linksys Router's config pages
simply look at http: // 192.168.1.1 (Linksys Router Homepage - remove spaces) on your home network, then look at the STATUS page to see the current DNS IP addresses listed.
Enter these into your iPhone wi-fi set-up
nutdhanai
Jul 15, 2007
Have you tried this? (mind you, i am using a activation-hacked iPhone, with att sim removed)
On your iPhone, go to -> settings -> general -> reset -> reset network settings
after that turn your wifi on/off then it should connect as usual..
hope this helps
Yantez
Jul 15, 2007
Same Problem
hope this helps
I had to update the firmware on my router - then it connected with no problems.
burniksapwet
Jul 5, 2007
553
I had this problem before. Call your internet provider and ask for the main DNS number. It is not the 192…. number.
  • Go to your wifi settings and under security make sure that you choose WEP hex or ASCII
  • Type in your password
  • Select the blue arrow next to the network you are connected to.
  • Select DNS.
  • Change the IP Address to what ever number your internet provider gave you. (I might be a 208……number)
Please let us know if this works.
cdodkin
Jul 2, 2007
305
SoCal
www.d30-images.com
  • Select DNS.
he can use the 192.168.1.1 address from a web browser to look at his Router, and get the DNS from the router itself.
You can then key those DNS numbers into the iPhone as you suggested.
burniksapwet
Jul 5, 2007
553
But doesn’t the router give him the 192 no? I really don’t know a whole lot about this but when I entered the one I found on my router it didn’t work. I had to call my internet provider and ask them the number and the number they gave me was nowhere to be found in any of my settings.
cdodkin
Jul 2, 2007
305
SoCal
www.d30-images.com
The Linksys router gives you a number of 'web pages' when you type it's IP address into your web browser. (192.168.1.1)
These allow you to set up your router using just a browser - and also see the settings that your ISP has given to the router.
When you look at the STATUS tab, you should see the IP addresses that your ISP has provided for DNS - these are ringed in red here - you can then type these IP addresses into your iPhone
burniksapwet
Jul 5, 2007
553
I guess its different with the type of router you have.:) Mine doesn't show it like that. I forget what type of router I have.
Xaero
Dec 31, 2007
Wi-Fi on the iPhone gave me the most pain in the world =) after trying EVERYTHING and EVERY solution posted online, i had no success. The damn thing was just NOT connecting. However, my dad who is a computer developer was able to figure it out after hours of searching.
The problem is that iPhone wi-fi does not support G connection from your router, its too damn fast for it. So what you have to do, is setup your router to not only support G connection, but also the slower type of connection, i think its called B or something
Here what you have to do:
Go to your router setup by typing in your own ip into the search window on the browser.
if you do not know your ip, click start, run, cmd, ipconfig; usually it is 192.168.1.1
If it was not setup before, leave the logic name blank, and for password type admin.
Finally, change the settings inside from G only to support the slower type. I am not sure where you do it in the settings, so just dig around or look it up on google.
After that, you're done! Sorry if my instructions arent completely clear, but its the only thing that worked for. GOOD LUCK!
KNK
Jul 22, 2007
2,391
Stevenson Ranch
Good post. The iPhone is setup for B & G, with G being faster. I however am on the Netgear Gigabit N and mine works spectacular.
