On the Go playlist problem
pside15
Jan 5, 2009
Ever since I have updated to 3.0 on my 3G my on the go playlist has been acting very strange. It is having issues playing "purchased" songs. If I add just purchased songs to the playlist it works just fine. But if I add any non-purchased songs it will no longer play the purchased songs at all. It will just cycle through the non-purchased songs over and over again. Anyone heard anything like this before?
BrownGem
Feb 27, 2009
1,623
22
Texas
You can try this link from Apple support. Instructions for deauthorize and reauthorize iTunes accounts, and recreating your library (I would try this one first) The article says Ipods but products affected lists the iPhone too.
http://support.apple.com/kb/TS1510 .
JimMayor007
Jun 27, 2007
46
Just check them in iTunes, sync, then uncheck them and re-sync.
pside15
Jan 5, 2009
Thanks for the replies guys. I will try tose when I get home from work. I just noticed something else about this that is even more strange about this. It will play purchased songs fine now aslong as the playlist isn't on shuffle. If the playlist just plays straight through it is fine. Weird.
