once logged into WiFi hot spot, how long...
sbpwjm
Jul 25, 2007
41
all,
once logged into a wifi hot spot, how long does your iPhone keep the connection active? seems like mine drops the connection after a while of inactivity and i have to log back in... not all that much fun with the wacky passcodes and such that some of my connection spots have..
sbp
iPhoneJones
Jul 13, 2007
52
To conserve topics, I will ask my question here since it is related to wi-fi. I can't log into hotspots hardly at all! What's the use of Wi-Fi if you can't log into other places? I have only been able to use my wi-fi at home and at one McDonalds close by. I tried it in another McDonalds elsewhere and it threw up a username and log in for their wifi system. I tried it in a restaurant last night and it connected but I couldn't get on the net or YouTube with it. Has anyone else experienced wi-fi connectivity?
So, to answer your question, I can't get connected most of the time.
adseguy
401
I tested through a continuous ping. It keeps a connection for about 2-3 minutes....I wasn't counting.
Your passwords, though, will be saved. you should be able to go to any area, enter the password once and leave. When you come back eventually the Wireless should find it and connect right to it with no intervention.
adseguy
401
That's all normal and not iPhone's fault.
1.) YOUR wireless setup at home may be faulty
2.) Not all McDonalds locations are free, hence the sign in and pay.
3.) Restaurants sometimes have wireless, but it may not be for public use so they shut down ports so only internal access can get what they need.
sbpwjm
Jul 25, 2007
41
hmmm..... i get differing results...
it seems to remember the iPhone at my parents..
i can't get my own Wi-Fi working at all...
at work... i am always have to put in the aruba networks wi-fi password...
sbpwjm
Jul 25, 2007
41
quick update - after the software update (1.0.1) i am able to connect without issue to my home wi-fi (linksys)...
definitely was not working before.. works like a champ now...
:cool:
