One Blank Icon
ADDam
Mar 2, 2008
439
Ann Arbor, MI
So I want a COMPLETELY Blank home screen, except for the dock. The easiest way I could think of doing this is having a Program or WebApp with an invisible Icon, and just move Everything Else to another page on the springboard.
Also, I know this a n00b Question, But How do I change the Background of the Home screen, I have a theme from SummerBoard with a Pretty Neat background... and just made my imagination fly with possibilities. And Yes, I'll Search too, just lookin for some instant gratification I guess. I just got my iPhone Yesterday and its already JB'd and I have been readin like a madman, I need to be a pro at this thing :cool:
michael180
Jun 14, 2007
1,249
Santa Cruz, CA
moderntimes.com
If you have Photoshop, or some other image program, you could create your own background, name it Wallpaper.png, and using OpenSSH upload to the directory where the particular theme you are using resides, and presto, a new background.
Good luck
Dec 10, 2007
710
blacked out
Install the application called "dock" (from Installer) then use customize to hide all icons except for those on the dock. The dock application will let you access all applications while their icons are invisible. Once installed you'll see a little yellow sunburst in the bottom right hand corner of the screen. Touch the sunburst and slide your finger up and to the left.. you'll see.
ADDam
Mar 2, 2008
439
Ann Arbor, MI
...Shot Down...
"You Must install the BSD Subsystem Package First"
So I tried to install the BSD SubSystem, And it says the Same thing...wtF?
Dec 10, 2007
710
blacked out
hmm.. you do need the BSD subsystem for dock.. as to why it says you still need BSD after an attempt to install, itself.. I dunno. Try again?
