One thing that increases battery life.....
xdawgg
Jul 17, 2007
14
I changed one setting and my battery has been charged for about 5 days now. I changed the mail settings to manual, and only check it about once a day, and boy did that make a difference. I use to have it every 30 minutes.
yippie!
brinky
Jul 24, 2007
95
50
Atlanta, Ga
yep, automatic e-mail check drains the battery. It was what caused me to do the yahoo push mail.
yahoo push does save battery, however I could never get yahoo to push on a regular basis. It would work great for a few days then it would quit. I finally gave up and just went back to .Mac and checking every 15 minutes. From my Treo I was used to charging it everynight, so the battery life doesn't bother me that much.
krossmusic
Aug 29, 2007
79
New York City
Amen to that brotha. That being the battery life on the Treo, I'm not a Treo hater ( I mean I've been using them since 03/04) but the 700wx OMG, awful batter, just awful!
josephvman
Jul 30, 2007
Push E-mail
Can someone explain "Push" E-mail to me? I'm assuming this means that the phone isn't constantly checking for mail, but receives mail as it's sent. Is that it? I noticed that if you use Yahoo mail there's no option under the Settings/Mail menu to adjust the checking of mail.
Macster
Feb 21, 2007
68
Oregon
yippie!
If you turn off the auto-brightness feature, that will also help with power usage. you will find that control in settings under brightness.
4mula1
Aug 4, 2007
24
Bluetooth
If you are not an avid bluetooth user it helps to turn that off as well. I used to only use bluetooth but since stereo bluetooth is not available on the iPhone I wear my included headset.
Rockky
Aug 8, 2007
333
checking e-mail every HOUR vs manual is really going to make that much difference?
Kipper
I have my mail set to check every 15 mins. all the time. Never really noticed a major drain on the battery but I mean common sense any app u having running is going to take some of the battery. I'm a UPS driver and on the road all day long and I also own/run a mustang website so I need to know as soon as I get an email. When I used to have the Dash I had to set to every 5 mins., lol.
Indy
Jul 29, 2007
2,921
41
In this book I'm reading the author states along with 'dimming the screen', 'turn off radios not being used'(cell, wifi, bluetooth) and 'not to check for email every 15 min.'. He also says to turn off 'wifi searching', 'fully drain and recharge at least once a month', 'turn off equalization (EQ) on both iPhone and iTunes' if you can get by without it of course.
So there's at least 5 things you can do to help battery life. =P
