Only speakerphone works
guysky
Dec 5, 2007
Suddenly phone audio stopped working. Can only hear or speak to people with speakerphone.
If I start a phone call with the earpiece plugged in, the earpiece works. If I plug the earpiece in during a call, it drops the call. Oddly, when I plug in the earpiece, it fires up the Ipod app and starts playing, regardless of what screen I was on.
But the ear speaker does not work in any instance. I think physically the ear speaker is functional, that somehow the phone is tricked into not communicating during the normal (non-speakerphone, non-earpiece) setting.
I have turned off phone and reset multiple times.
Any guesses?
jaydoc1
Sep 23, 2007
608
Try inserting and removing your headphones several times. This sometimes can remedy this situation.
guysky
Dec 5, 2007
JayDoc - brilliant. worked. thank you.
jaydoc1
Sep 23, 2007
608
Glad to help. Had the same problem myself.
420greg
Jun 26, 2007
845
Orlando, Florida
There is a little switch in the headphone that gets stuck sometimes. So your phone thinks the earphones are plugged in.
rmb
Sep 6, 2007
Thank you!
I just had the same problem and you solved it!
Niffy
Dec 8, 2012
When trying to answer or make a call I have to hit the speaker icon if I don't I hear nothing and neither does the caller
Any suggestions other than the headphone trick? I've never used the headphones or Bluetooth
