OpenSSL & OpenSSH question
ducati
Dec 30, 2008
71
Hey guys! Just jailbrakedvmi iPhone. Cydia and RockApp are telling me that I need to update to OpenSSL. What is it? What's the difference between OpenSSL and OpenSSH? Do you guys recommend downloading openssh? And if the answer is yes, how do I install it step by step and how do I protect myself? thanks
KabaModern
Mar 31, 2008
4,549
32
Philadelphia, Pennsylvania
OpenSSL is required to install OpenSSH (in fact, OpenSSH will install OpenSSL for you).
ducati
Dec 30, 2008
71
But why is that when I open Rock or Cydia it tells me that there is an update for me to install OpenSSl? Also does anyone have the step by step installation to install OpenSSH? Also I do I change the password onced installed? So that nobody hacks into my phone? Thanks
KabaModern
Mar 31, 2008
4,549
32
Just install it if it's telling you to update. Also, to install OpenSSH, search in Cydia for OpenSSH and install the package. And yes, I would highly recommend you change the password once you have OpenSSH installed. To do so, you'll need to install MobileTerminal. Let me know when you're there and I can provide directions on changing your "mobile" and "root" passwords.
ducati
Dec 30, 2008
71
Hi! Ok I have installed OpenSSH and the MobileTerminal. What's next? Thanks
ducati
Dec 30, 2008
71
Hello again. Never mind I was able to change the root password. But thanks for all your help.
iNinja
Aug 8, 2008
3,984
20
UK
OpenSSL? WFT is that? I just use SSH - is there something I should know?! lol
iNinja
Aug 8, 2008
3,984
20
UK
You have cleared it up perfectly. Juls was being asked the same thing in chat! haha
ducati
Dec 30, 2008
71
I went ahead and also changed the mobile password. Thanks
iphonewarrior
13,847
701
Guys I need to install OpenSSL.
Could you help me in that
thanks
OpenSSL or OpenSSH? OpenSSL should install upon jailbreak. Launch Cydia and click on the Installed tab, then tap view to change it to Expert. Scroll down and you should see that OpenSSL is installed. If it isn't simply search and install :p
