Organizing photos
Jan 16, 2009
3,230
59
Mississippi
Download the pictures from your ipad to your computer and organize them on your computer in a folder and then sync them back onto your ipad. Sucks but it's the only solution that I know of. I'm not sure but ios 5 may allow for photo organization and it will hopefully be out in the next 3-4 weeks.
alamarco
Nov 28, 2008
162
Canada
myfigurecollection.net
As Mickeylittle mentioned, syncing via a folder is the only way to sync photos. The only issue with this is you can't have sub-folders and sometimes photo order is random.
I still haven't found the time to look, but I'm positive there is a photo app out there that allows these type of features. For example, AVPlayerHD allows sub-folders and re-ordering of video files. You can sync via iTunes with the file sharing features and just drag and drop into the app. I'm sure an app like this exists for photos.
edit: I've only searched quickly, but Photo-Sort (from Romain HENRY) might help you out. It has sub-folders, you can import via iTunes File Sharing, import from the Camera Roll (and I believe other albums on the phone), etc. Really Photo-Sort seems like the best app at the moment.
Photo-Sort is $1.99 in the App Store.
John Tierney
Heretic
May 1, 2011
171
23
Massachusetts
There is an app on Cydia called PhotoAlbums+. It's a great tool that allows you to create albums and move pics around as you wish right from your iPad. I highly recommend it.
Db019y
Sep 29, 2011
You'll be able to manage photos, create folders and even edit photos on your ipad with ios 5
Db019y
Sep 29, 2011
There are multiple Apps that would help organize photos. The new iOS 5 has some photo organizing capabilities. Best way is to organize on the computer in whatever program used to import photos. Create sub folders which when syn ced back onto the ipad will become photo albums.
KevTN
Jan 16, 2011
45
Open photos....at the top click albums...click edit and create album pick pics and go to the next one...pretty simple
May 31, 2012
14
Hello, I am new to iPad and I've been searching here. Iread 'new os5 will allow folders' but I don't know OS version is this ipad but I can't find it. I finally found out how to move the icons around but I cannot put them in folders. It is the new iPad 3. Is there some way in this version to pull it off? I don't need this for photos - I want to put the apps in folders. :^)
Thank you for any ideas.
RoofMonkey
Jun 21, 2010
8,867
2,047
Go to Settings, about. That will tell you which iOS you have. If its the iPad 3, it's probably at least 5.1
On making folders: tap & hold an icon until it wiggles, then drag it onto another icon. This will create a folder for you. You can also rename the folder as well.
Folders for photos: go to your photo roll & press the arrow that hooks to the right. Select a few photos.
Select ADD TO
And you should see the option to create a new folder:
Dec 15, 2008
5,386
340
27
Pensacola, FL
It's the same way for all versions and devices. Here is a link that explains how to put apps in folders.
http://thehowto.wikidot.com/create-folder-for-ipad-apps
