os 3.0 killing my battery life
tiffanyleigh0212
Jan 10, 2009
57
Ever since i've updated to the new software 3.0 my battery life has gone to crap! it was fine yesterday.. but now doesn't stayed charged very long.. and i haven't been using it anymore than i normally do. anyone have any suggestions?
5,578
Settings -> General -> Bluetooth
Mar 24, 2009
1,005
Atlanta, GA
Also, check to see if your WiFi is on or off...
Those two are usually the culprits of poor battery life...
rojocrandall
Mar 2, 2009
424
Do you use Mobile Me? My 3G's battery drained like crazy after upgrade to 3.0, using Mobile Me/Find My iPhone. I deleted Mobile Me and it is back to normal.
tiffanyleigh0212
Jan 10, 2009
57
Bluetooth is off, I don't use mobile me, and wifi IS on, but i've always left it on and never had this problem *humph* also have ya'll noticed there isn't a 10% battery warning anymore. I get a 20% and that's it
GSA190
Oct 29, 2007
401
New York
ive been having the same problem and it is very annoying. I do not have bluetooth nor do i use mobile me. :mad:
JoeT
Dec 18, 2007
911
Tampa, FL
3G, Wifi, Bluetooth, and Location Services are all on - battery life is fine here.
BigCiX
Jul 11, 2008
1,445
Bakersfield, CA
Today my battery was full and within seconds of opening safari it dropped to about 1/3 full. 10 minutes after that I got the 20% indicator. Weird!
Dakine
Mar 29, 2009
31
808
Try turning off your phone or rebooting it.
Note I DID NOT say restore.
JTS2005
Sep 18, 2008
21
yes mines been losing charge faster since going to 3.0. i may just go back to 2.2 for now
iphonewarrior
13,847
702
I've had a few problems with my battery life, it seems to rapidly decrease.
From charging up after about 1 and bit days, i'm now charging it twice a day as my battery is going that quickly;
Overnight, then plugging it in at about 8 o'clock PM
shimrob
Nov 27, 2008
Kibbutz
advantages
hello everyone,
What advantages do you see that you have with the new f.w. 3.0?
Thank you.
iphonewarrior
13,847
702
hello everyone,
Thank you.
Your posting in the completely wrong section. Use the search function for 3.0 advantages.
bimmer91
Jun 19, 2009
i believe what's killing your battery life is the new notifications feature. i turned it off before i went to sleep, and my iPhone wasn't drained until about 11 this morning ( so it lasted 10 hrs on 20% battery)
iTrey.Bates
Jul 9, 2008
106
Texas
i have noticed my battery has been dying faster with the 3.0 update also...it doesn't really matter whats on and whats off because all the stuff i had on was on when i had the old update to so i know its the update...i don't think Apple factored in much how the great update would effect the battery life of the 3G and had primary focus on making the battery life with 3.0 update good for the 3GS.....
GSA190
Oct 29, 2007
401
New York
im going to disable notifications and hope that makes a change.
bimmer91
Jun 19, 2009
how do you turn the notifications feature off?
just click on settings and it's right under wifi. you might need an app that uses notifications to see it though, or that's what i have heard. i use textfree unlimited, but i think i read somewhere that ap mobile uses it as well.
