OTTERBOX COMMUTER CASE Feedback
Kgd0630
Aug 8, 2010
330
33
Anderson, SC
It's a good case and thinner than the defender! I have one of each and alternate depending on how rough of a day I'm going to have.
Kgd0630
Aug 8, 2010
330
33
Anderson, SC
It has more protection for drops and dust, but is a little more $$. I got mine off eBay and otter still honors warranty.
Bennyboy
Jul 21, 2010
14,017
1,731
PA
The defender is an epic fail. I bought it for my fiancée 3 months ago, pink.
Color as already faded to black, it's loose in every end and the plastic screen came off. Not worth $50 nor 10.
PinkBanana
Feb 16, 2010
1,476
94
Burnley, UK
Will update you in three months time with its progress. £20 was a bargain
Kgd0630
Aug 8, 2010
330
33
Anderson, SC
have you contacted otter? If its authentic, they cover all this under their warranty. And will replace the case.
Bennyboy
Jul 21, 2010
14,017
1,731
PA
I got it from an AT&T store, still have the receipt and everything. Somebody else told me that so as soon as I get a chance I will. I'm just very disappointed and I would never get one for me. Wish I could get my money back. I expected a bit more for 50 bucks.
Rbakfan
Jan 10, 2012
35
I really liked the commuter case for the 3G/s. the commuter for the 4/4s however has a tendency for the rubber to get loose. It is a really good design though. Comfortable to hold and slides in and out of pockets, and is relatively non-bulky.
Dano4715
Jan 19, 2012
9
I didn't care for the commuter for 3gs although I did use it quite a lot . The bottom port would always flop open. I love the commuter design for the 4s. I switch between that and a switcheasy trim. I have a Seidio Surface combo on the way.
