outgoing calls?
eab
Dec 30, 2007
Hi
My iPhone working fine except I can't make any outgoing calls?why?
I can send & receive sms also I can receive any incoming calls.
It is 1.1.2 unlocked
Help please
OJsakila
Jul 15, 2007
3,021
Jupiter's sulphur mines
ee gads! SOunds like it's not quite finished the unlocking instructions.......Were you in the process of unlocking it? Had it made calls before? More info please.
Eragon
Jan 8, 2008
3,056
50
Frederick, MD
Try this link:
http://modmyifone.com/forums/showthread.php?t=6738
Your phone is unlocked. Did your phone come with 1.1.2 firmware? Are you using a SIM different from the one that came with the iPhone?
KNK indicated elsewhere that the recent crop of iPhones can't be unlocked. Is it possible your phone really hasn't been unlocked?
I doubt it's 1.1.2 OOTB - they are impossible to unlock as of now. However, I suppose the OP might not have known this and attempted the unlock process on a 1.1.2 OOTB and only gotten partially through, doing something to the baseband and/or firmware.
I suggest attempting a Restore in iTunes, and if that doesn't seem to work, the using the iPhone Revirginizer.
- John
eab
Dec 30, 2007
thanks guys,
i think best and safe way is to restore in iTunes.
Cheers
