Outgoing Gmail issue
MACHINE
Sep 20, 2007
I'm having a problem with my gmail on the iPhone . The error I'm getting is when I open my email a popup thing comes up and says that connection to outgoing mail server SMTP.gmail.com has failed. Does anyone know how to fix this. Because I cannot send email and its getting pretty frustrating. I apologize If this is an easy fix im just not sure how to do it and its driving me nuts. Thanks in advance
tobey
Sep 11, 2007
79
I can't help you, but I'm having the same problem with my Comcast email account. I have sent emails through before though without issue, but recently I have had no luck. I turned off my WI-FI and am only attempting to send through the Edge network.
I'm wondering if it has something to do with signal strength, but even at 4 out of 5 bars I can not send an email. It sucks.
MaineWriter
Aug 13, 2007
33
On gmail, go into settings and make sure POP for all mail is enabled. This fixed it for me.
MW
MACHINE
Sep 20, 2007
tried that. it says POP has been enabled for all mail since august of last year
Sep 27, 2007
I added the port 465 to mine (smtp.gmail.com:465)
Also make sure you're using your whole email address as your username.
Good luck.
-DigitalOldschool
tobey
Sep 11, 2007
79
I fixed my own problem - I found that entering your username and password for the ingoing and outgoing mail fixed my sending problems.
MACHINE
Sep 20, 2007
Hey, thanks for the help guys. I appreciate it. I tried a few of the aforementioned suggestions, however nothing seemed to completely work... I am however not ruling out my error... anyway I just deleted my account and reloaded it again. and it seems to be working... for now. we shall see in a few days. I will keep you posted. thanks again.
