Outlook 2003 with Gmail help
hydro94530
Jul 3, 2007
325
:oops:Hi guys, first thread here, great forum so far. I searched and searched for this, so I apologize if this is posted somewhere else. I'm trying to use POP3 to sync gmail with my work Outlook 2003. I'm using the gmail troublshooter program, and when I use that it says my settings are correct. When I select to test the connection, the troublshooter program crahses.
On the Outlook side, after I set up and add the account using the gmail's configuratin guide, and select to test the settings, Outlook says it can locate the servers but that there is no activity, yadand it fails to send a test email.
Does Outlook not support POP3? Does it have to be IMAP through Yahoo? Any help would be greatly appreciated. Also, not sure if any of this is specific and depends on the person's company's firewalls, or what have you.
Thanks in advance.
hydro94530
Jul 3, 2007
325
Anyone have any ideas? I tried a few tutorials and they all tell me the same setup. Can't figure out what's wrong :(
