Outlook calendar sync problem
rkhogle
Aug 21, 2008
On a network managed system I tried to sync my touch with Outlook calendar and contacts. I manually managed both and selected the calendar I wanted as well as the contacts. Only the contacts came through even though the iTunes banner indicated it was syncing the calendar. No error message reported. Anyone else have the problem and find the solution.
mbecker6
Sep 6, 2008
never experiencing your problem, I would guess that iTunes was just confused with the title of the information syncing. As long as it works, it is no big deal. I have had different PDA-type devices in the past that do not claim to sync the same thing the computer claims to sync, but it all comes out ok in the end.
If your contacts start showing up in your calendar, you might have some worry. ;)
