Outlook calendar
gary1
Feb 18, 2009
I am running outlook 2000 and have filled in the fields for calendar synch. The synch seems to occur ( it says so in the iTunes panel) but when I check my outlook calendar nothing has been added. Am I missing something?
15,384
1,089
i think only 2003 and 2007 are officially supported.
6,682
49
Do a search for PST files on your PC and see if there is more than one in your Profile. It's possible that iTunes did not see you're original calendar and started a new Outlook profile.
gary1
Feb 18, 2009
Thanks. Will look into this
Gary1
gary1
Feb 18, 2009
Thanks. As far as I can tell there is only the one calendar. Will keep looking .
Gary1
