Outlook Contact Sync
RTOIPHONE
Jun 29, 2007
29
I saw on this forum or the Apple forum that the contacts will only synch from iTune to iPhone.
Today, I was able to synch in both directions. Contacts added Outlook or the iPhone will synch with each other.
LESLIEx317537
66
I'm using Vista and Outlook 2007 and mine syncs both ways.
The person is probably having Outlook sync issues like everyone else is having. At first, I couldn't sync all my contacts over, until I found this workaround I made up.
Give it more time, and they will fix more bugs.
LESLIEx317537
66
What do you mean?
I just enter a contact or edit a existing contact.
Hit Sync, and it's in Outlook after the Sync. If I edit in Outlook or add one, and sync, it will be added or edited on iPhone.
Goes both ways.
Just add/edit then sync. Can't be easier...
tigalig
Jul 8, 2007
Mine synched all of my contacts without allowing me the option to choose groups. So now I have over 300 contacts in my iPhone. :mad: Any idea how to fix that?
ColsTiger
Mar 8, 2007
5,856
Columbus, GA
Once you sync the iPhone with iTunes it goes through all the different sections: music, contacts, and calendar. If you've added some contacts or appointments, it will usually give you a warning message during the sync process that "syncing will change more than 5% of your contacts." Once you do that any changes you had added to your iPhone calendar or contacts, will now be on your Outlook contacts and calendar.
wjp09
Feb 25, 2007
2,559
25
NJ
What I am asking is how do you take contacts from iPhone and put them into OUTLOOK. I saw an import option but it didn't have FROM DEVICE as a choice. Am I missing something?
Britna
278
30
I would also like to know how to do this, as well.
Anyone know?
wjp09
Feb 25, 2007
2,559
25
NJ
Im using outlook 07 And under File I have IMPORT/EXPORT and then it bring up a list on HOW you would like to import it or export it. Not automatic.
ColsTiger
Mar 8, 2007
5,856
Columbus, GA
You don't do anything. IF you've got contacts or appointments on your phone that you don't have in your outlook software yet, when you plug up the phone it will automatically load those contacts and appointments to your computer.
wjp09
Feb 25, 2007
2,559
25
NJ
Ok I don't understand what your not getting. It is NOT syncing automatically, so I try to do it manually and it still dosn't work.
ColsTiger
Mar 8, 2007
5,856
Columbus, GA
There's not a manual option for moving the contacts from the phone to the computer. The only manual option you have is to move contacts from some other file into your outlook program. Once you select the Outlook options on the iTunes contacts page, it should sync both ways: from computer to phone and from phone to computer. It wouldn't be worth much if it didn't. The whole point is to be able to add appointments and contacts when you're away from your computer and then sync them with your desktop when you're back in the office.
LESLIEx317537
66
yes,
I just hit add new contact on my iPhone or edit a existing contact.
Then go home, plug into my PC and hit sync, and wala, it goes from my iPhone to my PC Outlook Contacts.
It's auto, no option to import etc...
LESLIEx317537
66
LOL, that option is to import your Outlook information to another program or file to back it up.
It has nothign to do with the iPhone!
You shouldn't have any options in Outlook for the iPhone!
It just adds a com plugin I'm pretty sure.
I would, uninstall iTunes.
Uninstall Outlook.
Reinstall Outlook. Make sure it's closed, and then reinstall iTunes.
I doubt trying it in the morning will fix it, unless it's a timer related issue. Most computer issues won't fix themselves.... lol
