Outlook contact to phone
jlau
Oct 29, 2007
Hi. The contacts is in Outlook and Windows address book. Opened iTunes and connected the phone, choose to sync the contacts from Outlook and the phone and iTune say it is sync. Go to the phone and no contact in the phone. How is the contact sync to the phone? How to fix the problem that it say that the contact is sync and is not? Thanks.
Griffinaz
Oct 5, 2007
1,046
Phoenix, Arizona
Open Outlook on the computer that you are syncing from and make sure that you show names within the Contacts and not just in the address book. In iTunes, make sure that you have the "Sync contacts from: (Outlook)" checked and that the "All contacts" is checked. If you look on your computer and notice that you don't have any contacts in there but have names in your address book you can select them in the address book and "add to contacts". The other option is to change the (Oulook) in the "sync contacts from:" to Windows Address Book. This will look in the address book rather than the contacts section within Outlook. If those do not help then I am at a loss. Sorry.
jlau
Oct 29, 2007
Thanks. Used this way and the contacts is not synced to the phone. The contacts is in Windows address book and there is no names in iTunes after the Windows address book is check. There is a problem using Independence unlock the phone from 1.1.1 to 1.0.2. There is problem for the SSH and the phone can't go to 1.1.1 after downgrade to 1.0.2 and phone is unlock and activated. Is the SSH a problem to sync the contact? How to check if the SSH is not right? How to fix it if not using Mac and fix it in Windows? Need to sync the contacts. Thanks.
theone77
Oct 18, 2007
73
all issues about this most solved here
read all post here
if you have an old firmware in iPhone 1.0.2 its better to have old iTunes also 7.3
just a suggestion bro, learn to search and read first in every forum that your joining. it will help you a lot, just a friendly advice...
Zachfj
Oct 10, 2007
You need microsoft 2003 or above. Is that the problem?
