Outlook/iTunes question?
Sep 19, 2007
I can't get iTunes and Outlook to talk. I'm trying to transfer my Outlook contacts and schedule into my iPhone, but iTunes won't sync up with outlook. Go figure Microsoft and Apple don't wanna cooperate. Does anyone have any ideas?
420greg
Jun 26, 2007
845
Orlando, Florida
Inside of Outlook.
Click on "Help/ABOUT MS Office Outlook"
Click on "Disabled Items"
You may have the plug-in for iTunes disabled, enable it and click Ok on everything.
Sep 19, 2007
Inside of Outlook.
Under "Disabled Items" it says "there are no disabled items." There is a iTunes plug-in for Outlook? Maybe I don't have it? Where can I get it?
eplantz
153
also check this:
go into Internet Explorer
click the TOOLS, Internet Options
click the PROGRAMS tab
make sure email and calendar are set to Outlook
Sep 19, 2007
Think I found the problem
Think I found the problem, my outlook is 2002. iTunes only supports 2003 and 2007. I'll try to get that updated and see what happens. Thanks for all the help!
